Hi
i make a batch file that work fine cuple of day and now i get this error
The following items have unresolved conflicts and will not be synchronized
what should i do
The Compare results give a reason for the unresolved conflict.
Files differing only by attributes or capitalization you may accept to leave as unresolved conflict.
If files have changed on both sides since the last sync, you may want resolve the conflict manually.
this is the massege that I get
Info: Comparison finished: 1 item found | Time elapsed: 00:00:00
[9:26:35 PM] Warning: The following items have unresolved conflicts and will not be synchronized:
Folder pair: ftp:// 212.143.60.16<-> D:\Finansit Pro DB\FTPFile
newusers-230519-142404.txt: Both sides have changed since last synchronization.
[9:26:35 PM] Info: Synchronizing folder pair: <-Two way->
ftp://212.143.60.16
who I order it manually?
ftp://212.143.60.16
If a file was changed in both locations since the last sync, FreeFileSync (FFS) has no clue what to do.
Any action it would take might cause a loss of data.
So, in those cases FFS simply concludes there is an unresolved conflict and the user (you) needs to resolve the conflict. Only the user may know if files have really changed in both locations and separate copies need to be kept, or which copy is the correct one and needs to be synced to the other side.
hi
I fix this problem but know I have another
when I sync tow why I see that its not save were I tell him
if he need to tkake a file from ftp and put it in a file he put in another file I liik in the batch and its seem o.k but I found that its saved on another place what should I do
That entire paragraph makes no sense. Please rewrite that with proper grammar so someone can help you
