GlobalSettings.xml error
sl23
Hi. I can no longer use FreeFileSync.
I recently moved away from PortableApps.com Menu to SyMenu.
I had the last working FreeFileSync version 6.2 on PA.c. I installed a later version to SyMenu. I wondered why PA.c hadn't updated FFS to the current 7.8, so I checked their site to find a bug report. I checked all this so as to remove the PA.c older 6.2 version and move to the newer SyMenu version 7.5. After deleting the PA.c version and trying to start the Symenu version I got an error I never had before, not even minutes before trying the two different versions to check which versions they were! The error is detailed better here on the PA.c bug page:
viewtopic.php?t=1716
Also, you will notice that I only have version 7.5 and not 7.8. The reason is that SyMenu's SPS system can't auto download using your links. So I had to use the zipped version from SnapFiles.com. Could you please provide a zipped version of FFS and allow auto downloads for apps like SyMenu's SPS.
The SPS system, btw, is a way of auto updating apps from any supplier unlike PA.c.
Thank you for reading and I do hope you can fix this issue and give some thought about my requests.
Scott
