Check for Program Updates
bapprentice
I have an Mac mini using OS 10.14.5. I just downloaded FreeFileSync 10.13 [Donation Edition] and I get the following error message when I startup the program.
Cannot find current FreeFileSync version number online. A Newer version is likely available. Check manually now?
Invalid HTTP response:""
I know I can disable "automatically checking for updates when I start the program" by clicking on Help and clicking on (Check automatically once a week) so that there is no check next to this item. This is just a workaround. The problem still remains. When I click on click on (Help > Check for Updates Now) I get the same error.
I also have a problem when I tried to activate the license as well.
I think that the problems are related.
Thanks,
Tracy
