Hello! I have experienced an issue, when I click compare there are several different files and then I click synchronise and the following error appears:
Server just don't allow me to insert error screenshot with unfriendly spammer warning message :/
So error is:
Cannot move file
"<somepath>.33bc.ffs_tmp" to
"<somepath>"
Error Code 183: Cannot create a file when that file already exists. [MoveFileEx]
I have several files with this issue. If it matters I'm syncing from local folder to network folder.
Sorry if it's a known issue. What can I do with it?
linzner
I do have the same issue. My connection is over a slow VPN connection. Folder with a few files do work, folders with more than 10000 elements seem to get those issues.
I tried splitting those folders up into different pairs and it seems to help, but it is not quite a good solution, as new folders might not be synchronized and with more than 10000 Elements it is a pain to do that.
I will further try to find a solution that works for me. If I do find a workaround, I will keep you posted.
