FFS can already detect file renames on local drives quite reliably by using file ID on supported filesystems.
However, it doesn't yet do this on Google Drive. A cloud side rename on Google Drive will be treated as a delete+new file.
Google Drive provides a stable file ID for each file, it can used the same way filesystems' file IDs are used to detect renames, and avoid unnecessary file transfers.
[Feature request] Detect file renames on Google Drive
The problem is Google drive also changes the modification time when a file is renamed. (This is stupid and) the result is that from an external point of view it looks as if the file content has changed. So this is more a design issue with Google Drive, which perfectly models a key/value store, but doesn't match well onto classical hierarchical file systems.
I did not know this. This is unfortunate.
Upon further testing, I see that FFS can already detect renames on Google Drive as long as the rename is done by a client that purposefully preserves file modtime (e.g. FFS itself), so my "feature request" is already fulfilled. I'm very satisfied with this.
Thanks for the help and the software!
