Hi, I used FreeFileSync, but I used to call data saved in built-in hdd
I created a folder and saved necessary data. Recently hdd breaks and data jumps
The system was backed up, so I restored it.
Did. Select the built-in hdd data save on the left side Save data to external hdd bk folder creation
At this time, it will complete without problems, but select individual folders under the left data save.
When the synchronous processing is performed with the data save bk, the left side is “target folder input field is blank.
You I can not back up the file with the error 'Gugging the net is applicable
There was no item, I saw the forum, but there was no corresponding item.
I do not know, thank you. I used machine translation because I can not speak English. I think there are some strange parts when viewed from English, but please forgive me
Target folder input field is blank
