Syncing from command line
lee88
Ive noticed that there is a possibility to sync from command line using free file sync, but couldnt figure how to use it with real time sync
Any help?
Thanks!
Create and save a job in FFS.
Find that file in "File Explorer" then drag it onto the RTS window. It will auto populate the monitored folders with the source and destination. You can change the idle delay, then save the RTS job.
You can then run
"start "" "%PROGRAM FILES%\Freefilesync\realtimesync.exe" "%USERPROFILE%\documents\RTS jobs\A to B sync.ffs_real"
lee88
It works!
Thanks!!
