So I´m new to the program and so far it has been a great experience. It is straight forward to use and pretty useful, however, I would like to create a scheduled task to synchronize every time my computer detects a specific external USB hard drive. I now how to setup the scheduled task up till the part when I need to set up the trigger. I have been searching and I cant seem to find how to setup the trigger. I would appreciate some help here please.
Thanks,
Alejandro Garcia
Synchronization on drive detection
Use RTS. It will monitor the two directories. Once you plug it in, it will see the directory, then trigger a sync after the idle delay time you set in RTS.
