RealTimeSync in Windows 10 fills Event Log with RestartManager messages
ratavaz
Hi all,
in my windows 10 machine, since I updated to the latest 10.15 version, whenever RealTimeSync is running it causes Windows RestartManager to generate 3/4 pairs of events 10000 and 10001 every second. This behavior fills up quickly Event Monitor window, creates huge log files and has also a significant impact on the CPU.
It is enough to have RealTimeSync running and performing Directory Monitoring.
As soon as I switch it off, the events generation immediately stop.
I hadn't updated FreeFileSync for quite a while, probably at least 5/6 months and previous versions didn't exhibit this behaviour.
Is there any way to prevent this logging to appear or any workaround to limit the logging?
Best Regards
Paolo
I don't think RTS is causing this. FFS on the other hand uses RestartManager to get additional error info when failing to open a locked file.
