Hi.
My MTP device (a Moto G 2015) apparently doesn't support moving files through MTP.
Could you make it possible that files get deleted and copied again instead of trying to move them?
Thank you
PS: I think this might be the wrong category for this topic. If necessary feel free to move.
Feature request for MTP. Delete and Copy files instead of trying to move them.
I assume you're using the "two-way" variant, because for "mirror" you have to opt-in into detection of moved files? What full error message do you get when moving a file on the device fails?
I have the same problem with the BQ Aquaris E4.5
Error message:
Cannot move file
"mtp:\Aquaris E4.5\Память телефона\Notifications\Elements.m4a" to
"mtp:\Aquaris E4.5\Память телефона\Ringtones\Elements.m4a".
Error calling "IPortableDeviceContent::Move".
HRESULT: 0x80070032, Такой запрос не поддерживается.
Thank you!
Error message:
Cannot move file
Thank you!
FreeFileSync now supports MTP devices that don't implement a move command:
https://www.mediafire.com/file/6wt7qtw59zfj59g/FreeFileSync_10.10_%5BBeta%5D_Windows_Setup.exe
