[bug] Not syncronizing with SharePoint after recent update
alexander.maximenko
Qestion to developer: I've noticed a bug after recent update: when syncronizing with Microsoft SharePoint, every file get's an error
[15:59:53] Error: Cannot copy file
"file.pdf" to
"file~3f21.ffs_tmp".
Error Code 222: The file type being saved or retrieved has been blocked. [CopyFileEx]
When I disable "failsafe copy" in settings it works. I believe this is because SharePoint blocks any files containing "~" sign in the filename. Would it be possible to add a setting to configure a pattern for this TMP file, or, at least avoid any special characters in the suffix of TMP files?
