Greetings
As a small team in a company, we bought the FFS Donation Edition for 5€ for the purpose of testing.
We found that in the FAQ there is a Donation Calculator for N-Numbers of Users.
How would this work exactly when we plan on deploying the Software with SCCM onto Devices?
Example: we buy 10 Licenses with Support up to 12 Months.
Do we get 10 License Key Files or does one license file work for all 10 installations? is the License Key File deployable with SCCM as an Install Parameter?
Problem is that the devices we deploy FFS to don't have internet access and are routinely staged new.
Do we have to do the activation of the license each time the FFS is deployed a-new?
Thanks in Advance
FFS deployment via SCCM
Activation requires an Internet access. Offline-activation is possible as a workaround but this is a manual step. Alternatively a portable installation could be used that is accessible from multiple PCs.
Thank you for your quick reply.
How does the portable version check if the license is compliant and that there are enough licenses for all users that are using it?
Would we be able to create a sheduled task in windows whith a configuration on the portable version?
Thanks in advance
Thanks in advance
The portable version has no limit, as long as it is run from a "removable" device
