I am using FreeFileSync 10.17 build 10/17/2019 - Unicode x64 on Debian 10 and Xfce 4.12.
I am getting a lot of Cannot write file Error Code 22: Invalid argument [open]
They are always in the format of filename~xxxx.ffs_tmp
I also got an error of Cannot move file Error Code 17: File exists [rename]
It appears that this one is the same file format as above trying to write to filename.bak.
My target is a new USB flash drive with plenty of space.
How can I fix this problem?
Thanks.
Error Code 22
