Dear community,
I am wondering if the following is possible: I have a large collection of files in my sync folder (about 50GB of many smaller files) which I sync with a USB drive to move between workplaces.
As only a small fraction of these files changes every time, the scanning of files takes a long time while the copying is rather quick. Now I am thinking about the real time sync option so that I won't have to wait for 10 or so minutes each time when closing down. However, I also really like the fact that I have a kind of a short-term backup on the USB stick which remains save even if the PC crashes (as long as it doesn't crash during sync).
So I would like RealFileSync to monitor my file changes but it should delay the sync itself until I am finished with work, thus on demand. Is this currently possible?
Many thanks for your insights!
Bob
RealFileSync: monitoring only, sync on demand?
No. After RealTimeSync (RTS) has detected one or more changes in the specified folders and no newer change has occurred during the RTS idle-time, RTS will launch the specified application, normally FreeFileSync (FFS).So I would like RealFileSync to monitor my file changes but it should delay the sync itself until I am finished with work, thus on demand. Is this currently possible?
I don't know why you want to wait running the FFS Compare+Sync.
Looking at your description, it seems best to split your RTS and FFS tasks in multiple (e.g. 10) smaller portions.
You should then have each RTS task monitor a separate ~10% of your 50GB of files/folders, and have each RTS task launch a dedicated FFS Compare+Sync for the files/folders monitored by that RTS task.
Part of your syncs will then run while you are still working, while your last Compare+Sync (which may still run at/towards the end) will only last ~10% of the time of your present full Compare+Sync.
If you really want/need to do what you describe, it seems you need a folder monitoring tool that logs any changes to a log-file, and upon shutdown run a script to sync all logged changes to your USB disk/stick (and clears the log).
I am not aware of any such tools, albeit those may exist.
But at least RTS and FFS can (presently) not do that for you.
