Suppress the pop-up window in RealTime
hmm1
When RealTime finds a change in a monitored folder, the program pop-up window appears (showing the progress of the synchronization, the same as when running a FreeFileSync batch file independently of RealTime).
How do I suppress this pop-up window from appeariing? (The RealTime help directs me to the command language help, which doesn't answer the question. Also, typing "-> FreeFileSync -h" does not give an answer.)
Thanks for your help.
hiroo916
I have a similar question. I don't have a problem with the progress window, but after the sync completes, it becomes a completed window, and if nobody clicks close, then subsequent monitoring doesn't continue. I want this to run on a remote computer unattended so nobody is available to click the close button.
Can this be made to work?
hiroo916
ok, i found that you have to select "Run Minimized" and select "On Completion: Close Progress Dialog" during the save of the batch file. I was looking for the option in the RealTimeSync app, not at the batch file creation stage.
Cichx
I had the exact same problem. Thanks!
