Stuck! ERROR mentionning RecycleBin?
fran330
I have used FFS for a few years, no problem, except today.
- First the synchronisation was much much slower than usual and seemed stuck. I clicked the button "Stop"
- It got stuck in the Stop process (white veil on FFS window, disk icon going round and round).
- I then closed FFS through the Windows Task Manager.
- In my target folder, I noticed 2 new folder: RecycleBin~63e4.ffs_tmp and RecycleBin~a7e8.ffs_tmp
- I re-opened FFS. It did the comparison process then started the synchronization process, but at once showed this Error message:
Impossible de déplacer le fichier
"E:\hubiC\Ajwan Medias\RecycleBin~a7e8.ffs_tmp" vers
"E:\hubiC\Ajwan Medias\RecycleBin~63e4.ffs_tmp\RecycleBin~a7e8.ffs_tmp".
Code Erreur 5: Accès refusé. [MoveFileEx]
1st line means: "Impossible to move the file", last line means "Error Code: Refused access"
- I cancelled the synchronization.
Here is what the comparison shows:
Hmm Wanted to show a screencap but got a very agressive automatic message, so...
Anyway now I don't know what to do in order to not lose files on any on my drives and in order to synchonize successfully.
I would greatly appreciate some help.
Fran
Delete those two files and try again
fran330
Thank for this simple reply. I did it and the following synchro worked. Thank you!
