Syncronise Linux Windows problems
pmoren
HI:
I use windows and Ubuntu Linux in two different machines. In both cases all my partition disk is encripted using truecrypt. When I tryed to syncronize, FreeFileSync found changes in files that hasnt change at all. Even when I view a directory without making any change, it takes as if all the directory has change, and wants to copy all. So, FreeFileSync, wants to copy like 8 gygas and thousands of files, only when a few files ( a few megas) has changed.
Do you have any idea how I can fix that?
You can check yourself what has changed: see the middle grid in the main dialog.
pmoren
Thanks, for your answer. I have see what are the problems.
There appers to be two problems:
1) Some file has name with accents, so it seems that linux and windows manage this in differents ways.
2) The other problem, is that for some reason date has change from files that I havent change in year. All the files has 1 hour exactly of difference. Even when this files havents change since 2009.
I know that maybe this is not excatly a problem of FreeFileSync, but do you have any idea why is this happening?
THanks
