I want to know how to get the settings of the following situation.
There are folders A and B. A part of the files in A exist in B.
For example, there are X, Y, Z, W files in A and X, Y in B.
When files in B are modified, I want to update the file in A.
Under the standard settings, Z and W in A are deleted since there are no Z and W in B,
But I want to prevent them from being deleted.
Also, I want to prevent X in A to be deleted even if file X in B is deleted.
In other words, I want to update only the existing files in B to A and not to reflect the information of deleting or adding the files in B.
Is there any way to set this situation?
Best regards.
Syncro without deleting nor adding file
It seems you have to look into defining a Custom sync variant,
and define your preferred Action per Compare Category.
