Virtual Drive Display & Select
Mwyarm
I have a virtual drive that I can visibly see and copy contents from and to using explorer. However, when I select the same virtual drive with FFS it is not displayed. I also used TrueCrpt and VeraCrypt and both applications can see the virtual drive. I am on version 10.18
Is there an option I must select to visibly see and select a virtual drive?
Do you mean via the folder picker? Selecting a Truecrypt-mounted volume works fine in my tests.
Mwyarm
Truecrypt was one of the applications that worked but FreeFileSynch did not. After trying different things, reboots, etc. I decided to downgrade back one version and that did not work. So, I decided to uninstall FFS and reboot fresh. I reinstalled 10.18 and it now works.
I have no idea why it stopped working but with a fresh reinstall it is working again. Thank lord. I have donated to FFS and I love the product so I hope everyone continues to invest to keep it alive with lots of functions.
