Hello, when I run FreeFileSync as administrator, I am not able to even view (while browsing) any mounted Cryptomator drives. They show up and can be used while NOT administrator.
I need to run as administrator to sync locked Outlook ost files (for later conversion to pst with free software Data Numen Exchange Recovery allowing import to Outlook).
Is there a way to force them to be seen and therefore able to be selected? Typing in the path results in error:
Cannot find the following folders:
X:\
Cannot read file attributes of "X:\".
Error Code 3: The system cannot find the path specified. [GetFileAttributes]
Running as administrator hides mounted drives (Cryptomator)
Assigned drive letters are user specific.
Drive X:\ for one user my point to another location for another user, or may not have been defined.
Simply define a (permanent) drive X:\ (pointing to the same/correct location) for the admin account under which you run FFS.
