Cellphone Files Not Found in New FFS Versions
Jerry
I like to sync data between my cellphone and my (Linux) laptop over USB using FreeFileSync.
Unfortunately versions later than FreeFileSync_10.17_Linux do not support this. What happens is that when I open my file manager and click on my cellphone, no file tree appears. So I still use FreeFileSync_10.17_Linux, even though FreeFileSync_10.19_Linux is released.
I no longer support FFS financially because of this.
I have a suspicion what might have caused this (although I'm surprised that MTP access via FFS worked at all in the past). Does the following version work on your Linux system? (Which is it BTW?)
https://www.mediafire.com/file/scrkdh3ymo38srv/FreeFileSync_10.20_beta_Linux.tar.gz
Heiko
With the version 10.20 beta it works like 10.17 .OS: Linux Mint Cinnamon 19.3 64-Bit.
Greetings from Germany
Heiko
Jerry
I sincerely apologize that I did not see Zenju's 29 Dec, 2019 response or I would have replied.
The good news is that I have downloaded the new public version, 10.20, and it works fine for me.
Thank you FreeFileSync / Zenju.
tofinofin
Hi. Sorry to ask. But I have seen that again sync between LInux (currently MINT 20.1) is not working. To be honest it is since many versions that I cannot use for phoone (probably from 11). the files are detected on both side correctly but then the copy action does not work.
it is a pity as the program is very cool.
thanks for any help
example below
07:41:16 PM Error Cannot move file
"/run/user/1000/gvfs/mtp:host=Xiaomi_SDM660-MTP__SN%3AE6511D71_5313ccf9/Internal shared storage/A_Vivi/X_VARIE/posti da vedere~ff52.ffs_tmp" to
"/run/user/1000/gvfs/mtp:host=Xiaomi_SDM660-MTP__SN%3AE6511D71_5313ccf9/Internal shared storage/A_Vivi/X_VARIE/posti da vedere.txt".
Error Code 5: Input/output error [rename]
07:41:16 PM Error Stopped
