Sync both ways (delete is only working one way)
hispeed
Setup:
1 Computer with local drive: H:\
1 Network storage where I want to syncrhonize into: I:\Daten
I have set up succesfully a job with Relatimesync and Freefilesync.exe. The job starts at logon in the background. When I create a file on the local hard drive: H:\ -> those file are being synchronized. When i delete local a file it is also deleted on the NAS.
When I create a new file on the network drive I:\Daten this new document is also syncrhonized back to local drive: H:\ .
So far everything works fine.
Problem:
When I delete now on the network drive a file this file is not deleted on the local H:\ -> Why not?
I don't recieve any error or so. The file is just staying on the local hard drive H:\ forever even after reboot.
Any help is welcome.
Best Regards,
hispeed
Anyone here who has an idea the problem is not yet solved?
Don't troubleshoot this by letting it sync automatically. Try to re-create the problem and do a manual compare, but don't sync, and see what the comparison window shows
hispeed
Hi this topic can be closed. The sync process is working fine now.
