Huge file FTP transfer
leopondolo
Hi everyone,
I am experiencing troubles in uploading a 100+ GB file to an FTP server.
If upload a smaller file (<20GB) all is ok and the FTP log (filezilla server side) is something like this:
(000357)20/01/2020 14.52.07 - <my_username> (<public_ip_of_ffsync_client>)> EPSV
(000357)20/01/2020 14.52.07 - <my_username> (<public_ip_of_ffsync_client>)> 229 Entering Extended Passive Mode (|||53930|)
(000357)20/01/2020 14.52.07 - <my_username> (<public_ip_of_ffsync_client>)> STOR /TS-DB~34c6.ffs_tmp
(000357)20/01/2020 14.52.07 - <my_username> (<public_ip_of_ffsync_client>)> 150 Opening data channel for file upload to server of "/TS-DB~34c6.ffs_tmp"
(000357)20/01/2020 14.52.07 - <my_username> (<public_ip_of_ffsync_client>)> 226 Successfully transferred "/TS-DB~34c6.ffs_tmp"
(000357)20/01/2020 14.52.07 - <my_username> (<public_ip_of_ffsync_client>)> MFMT 20200119100038 /TS-DB~34c6.ffs_tmp
(000357)20/01/2020 14.52.07 - <my_username> (<public_ip_of_ffsync_client>)> 213 modify=20200119100038; /TS-DB~34c6.ffs_tmp
(000357)20/01/2020 14.52.07 - <my_username> (<public_ip_of_ffsync_client>)> RNFR /TS-DB~34c6.ffs_tmp
(000357)20/01/2020 14.52.07 - <my_username> (<public_ip_of_ffsync_client>)> 350 File exists, ready for destination name.
(000357)20/01/2020 14.52.07 - <my_username> (<public_ip_of_ffsync_client>)> RNTO /TS-DB.vbm
(000357)20/01/2020 14.52.07 - <my_username> (<public_ip_of_ffsync_client>)> 250 file renamed successful
When the file is huge the phase MFMT-RNFR-RNTO is missing. The client simply disconnects and after 3 minutes it logs in back and delete the .tmp file, like this:
(000361)20/01/2020 23.14.46 - <my_username> (<public_ip_of_ffsync_client>)> EPSV
(000361)20/01/2020 23.14.46 - <my_username> (<public_ip_of_ffsync_client>)> 229 Entering Extended Passive Mode (|||57958|)
(000361)20/01/2020 23.14.46 - <my_username> (<public_ip_of_ffsync_client>)> STOR /TS-DBD2020-01-19T104756_D634~17e2.ffs_tmp
(000361)20/01/2020 23.14.46 - <my_username> (<public_ip_of_ffsync_client>)> 150 Opening data channel for file upload to server of "/TS-DBD2020-01-19T104756_D634~17e2.ffs_tmp"
(000361)21/01/2020 04.39.37 - <my_username> (<public_ip_of_ffsync_client>)> 226 Successfully transferred "/TS-DBD2020-01-19T104756_D634~17e2.ffs_tmp"
(000361)21/01/2020 04.39.56 - <my_username> (<public_ip_of_ffsync_client>)> disconnected.
(000363)21/01/2020 04.42.58 - (not logged in) (<public_ip_of_ffsync_client>)> Connected on port 21, sending welcome message...
(000363)21/01/2020 04.42.58 - (not logged in) (<public_ip_of_ffsync_client>)> 220-FileZilla Server 0.9.60 beta
(000363)21/01/2020 04.42.58 - (not logged in) (<public_ip_of_ffsync_client>)> 220-written by Tim Kosse (<email of filezilla creator>)
(000363)21/01/2020 04.42.58 - (not logged in) (<public_ip_of_ffsync_client>)> 220 Please visit **********/
(000363)21/01/2020 04.42.58 - (not logged in) (<public_ip_of_ffsync_client>)> USER <my_username>
(000363)21/01/2020 04.42.58 - (not logged in) (<public_ip_of_ffsync_client>)> 331 Password required for <my_username>
(000363)21/01/2020 04.42.58 - (not logged in) (<public_ip_of_ffsync_client>)> PASS ******
(000363)21/01/2020 04.42.58 - <my_username> (<public_ip_of_ffsync_client>)> 230 Logged on
(000363)21/01/2020 04.42.58 - <my_username> (<public_ip_of_ffsync_client>)> PWD
(000363)21/01/2020 04.42.58 - <my_username> (<public_ip_of_ffsync_client>)> 257 "/" is current directory.
(000363)21/01/2020 04.42.58 - <my_username> (<public_ip_of_ffsync_client>)> CLNT FreeFileSync
(000363)21/01/2020 04.42.58 - <my_username> (<public_ip_of_ffsync_client>)> 200 Don't care
(000363)21/01/2020 04.42.58 - <my_username> (<public_ip_of_ffsync_client>)> OPTS UTF8 ON
(000363)21/01/2020 04.42.58 - <my_username> (<public_ip_of_ffsync_client>)> 202 UTF8 mode is always enabled. No need to send this command.
(000363)21/01/2020 04.42.58 - <my_username> (<public_ip_of_ffsync_client>)> DELE /TS-DBD2020-01-19T104756_D634~17e2.ffs_tmp
(000363)21/01/2020 04.42.59 - <my_username> (<public_ip_of_ffsync_client>)> 250 File deleted successfully
(000363)21/01/2020 04.43.20 - <my_username> (<public_ip_of_ffsync_client>)> QUIT
(000363)21/01/2020 04.43.20 - <my_username> (<public_ip_of_ffsync_client>)> 221 Goodbye
(000363)21/01/2020 04.43.20 - <my_username> (<public_ip_of_ffsync_client>)> disconnected.
Any idea on how to make the transfer work ?
Thank you
leopondolo
No idea at all ???
Developers ??
What error message is FreeFileSync showing?
leopondolo
This is what FFSYNC log says:
(translated in english)
16:33:40 Error Cannot write the file "ftp://<my_ftp_site_address>/TS-DBD2020-01-19T104756_D634~b5c8.ffs_tmp".
CURLE_OPERATION_TIMEDOUT: FTP response timeout
150 Opening data channel for file upload to server of "/TS-DBD2020-01-19T104756_D634~b5c8.ffs_tmp" [curl_easy_perform]
16:33:40 Error Stop
I don't think this time out is caused by anything set up by FFS (assuming that the user-configurable time out is large enough, which FFS will pass on via CURLOPT_FTP_RESPONSE_TIMEOUT). The project lead of libcurl has this to say:
https://curl-library.cool.haxx.narkive.com/97FKNitM/curle-operation-timedout-when-ftp-upload-with-large-files#post2
But maybe we can work around. Here's a version enabling CURLOPT_TCP_KEEPALIVE. Does it fix the time out problem?
https://www.mediafire.com/file/jhjz5s4ymufc2qk/FreeFileSync_10.20_%5BBeta%5D_Windows_Setup.exe
leopondolo
I will test it tonight, Zenju. Thank you very much for your support !!! :-)
leopondolo
It worked like a charm, Zenju. Thanks a lot for your support. FFSYNC is top !!!!
douzaine
Zenju, I may be having a similar problem.
I tried to download the Beta version enabling CURLOPT_TCP_KEEPALIVE in your post above, but it's not on Mediafire anymore.
Could you please provide me with another link?
douzaine, as of version 10.20, that feature is implemented in the stable release. Download any version equal to or newer and you are set
