Starts but does nothing in Task Scheduler on Win7 and Win8.1
created Task Scheduler tasks, with Minimize and Ignore Errors options checked. Saved as a batch job, scheduled in Task Manager. When I Manually run the Task to test it, FreeFileSync loads into memory and sits there with 0% CPU utilization and does nothing. I kill the tasks, and run manually and it works properly. This was working about 30 days back. Did anything change as a result of Windows Updates? This is true on version 6.9 and 7.1
Solved the problem.
In Task Manager, the Start In field must be filled in with the path to where the FFS_BATCH file is located!
