Migrating from Mac-compatible volumes to Windows-only volumes: on the source there are files with leading spaces (or even double leading spaces) which aren't copied to the Windows-destination because this volume doesn't support leading spaces.
Any solution would be nice: default replacement of "faulty" characters with "_" or "~" or something together with an entry in the error-log...
Or a regex find combined with a fixed character replacement would also be nice...
Thnx for the great software anyhow!
Henk
Feature Request: rename files during sync
