This is an amazing tool! Though, i'm running into a couple of difficulties and i'd like to check if there is a solution/workaround or if it can be fixed/added in future versions.
1- Google drive accept folders with specials characters (like "/", ie: "Folder 01/01/2020"). Is there a way to specifically tell if the folder/files names that will be copied/created must comply with Windows requirements and then force the file/folder name to be compliant or provide a generic character to replace any special character in a list (ie: "/"->".", " "->"_", etc...) instead of just logging an error?
2- Google drive also accepts a space ([edited] and a dot) as last characters of a folder name. Similar question, can we either replace those characters with another character of suppress them instead of just logging an error?
Thank you
Google Drive - Folder creation error / file error / log file
is anyone working on this ,I have a lot of files with _ in them
thanks
thanks
@armirol :
The only resolve seems to be to run a separate script that replaces all (for Windows) illegal characters in Google drive before running an FFS sync.
@ngdavo :
An underscore (_) is a perfectly legal character in (also Windows) filenames,
and syncs just fine in FFS.
@ngdavo :
@ngdayo:
Underscore is not an issue, the other specials characters are: / or space at the beginning or end of a folder or filename... right now we have to rename all files/folders manually... it's a question of training the team to pay attention to those details, so we'll get less and less mistakes but i still need to monitor the log after each sync.
@Plerry:
That's exactly what i was saying..." "->"_" meaning replace " " with "_" as space at the beginning or end is an issue with the sync as replacing all spaces by underscores would solve the problem with windows.
Else, how would you run a script on a google drive to solve those files/folders names compliance issue? I have no idea where to start.
Thx
@Plerry:
Thx
Underscore is an issue, I moved a subfolder with 12 files in windows and only 6 files moved and it renamed some of those by trunking the end of the file names witch is worse then just failing is did damage to that subfolder
