they clearly are syncing though I don't understand why just these files in particular.. I hope it isn't to do with cancelling a sync towards it's very end when someone called-in...
I already backed up card, not exactly wanting to format & do so again (~3hrs)
Anyways this should explain it very clearly...
[404, Invalid URL: http://www.semiotically.com/screenshott.png]
Version 6, using new SD card, small% files out of sync by one hour and repeatedly running sync doesn't fix..?
anyone?? hi again, just to say it also is running the 'Encoding Extended Time Information' at the end..
bump, also why 1979/1980 ???
So, the problem is that these files will show up as different, even after sync? What if you delete some of the files on the right hand side, does sync work then and "stick"?
Hi Just tried deleting them, run sync, then run sync again - and the same 50 files are 'out of sync'... actually formatted stick before backing up again previously... thought you might know off-hand, it's not really an issue as just an hour out... I was just caught unawares at first...
Actually a little concerned FreeFilesSync might have altered these source file's dates, is this a possibility?
FreeFileSync doesn't change the file modification times, but it's possible that the target drive doesn't store them correctly, so that after synchronization the file still look as if not in sync.
