Suppress warning in log?
florentine
Is there a way to suppress a particular warning (so, not all warnings, just chosen ones) in the logfile?
I have two identical folder pairs in a sync operation, but they exclude different sets of child folders in order to use different settings. I always get a warning in the logfile about it. Is it possible to suppress particular warnings?
I found some older forum threads but no solutions to them. Is this just not currently possible?
Thanks!
What is the warning that you get? It shouldn't give warnings if it is set up correctly, meaning there shouldn't be conflicts
florentine
This is the warning:
Warning:  Some files will be synchronized as part of multiple base folders.
                        To avoid conflicts, set up exclude filters so that each updated file is included by only one base folder.
                        G:\Destination
The sync is setup like this in the same FFS batch file:
Main config
Include: *.*
Exclude: defaults
Pair 1:
Source: C:\Source
Destination: G:\Destination
Include: *.*
Exclude: a, b, c, d
Pair 2:
Source: C:\Source
Include: a, b, c, d
Exclude:
There's no actual overlap so I would like to not have the log file show as a warning every single time.
Fixed in FFS 11.24! viewtopic.php?t=9365#p34930
