Hi all,
I want to use FreeFileSync to sync from server1 to server2. My question is now: Are the files copied from server 1 to the remote PC (my laptop) and copied then again onto server2, or are the files copied directly from server1 to server2?
Thanks.
Sync from Server to Server
FFS has no means to initiate direct data transfer between server 1 and server 2,
so the data-flow is always
(server 1) => (machine running FFS) => (server 2) or vice versa.
Only if server 1 or server 2 would be running FFS, you would skip this step in between.
Hi Plerry,
thanks for your reply. Then I have to think about another way.
Elchico, this may be too late to be of use but... I have two NAS's, a QNAP and a Terramaster. I found that to do a direct NAS to NAS file transfer I needed to use Rsync. It runs on the NAS's, not my workstation. I'm not geek enough to give much of a technical explanation but Rsync appears to have been around for a very long time and is ubiquitous enough that you may already have it on your servers.
