I am using FFS to backup my local stuff to my OneDrive. If I use FFS two-way, the tool creates databases on my local storage as well as on onedrive. Here's a problem: I'm using 2 PCs that access the same folders on onedrive. Both use two-way. Is there any chance that FFS might get confused and detects files as deleted or moved even if they aren't? I mean, the 2 FFS instances might probably overwrite each others database. Am I right? Can I safely use two-way on multiple machines?
Greetings,
Flo
Two-way databases
