Windows Error 5
aiwatson
Just started with this product and hit an issue where a directory created on
the left list is not created on the right side when a sync is run. If there is
a directory on the right list which does not exist on the left the directory
is created without error. The left side is a local drive directory, the right
side a UNC connection to a remote PC.
Windows Error 5 is ERROR_ACCESS_DENIED. Make sure your user has all the
required permissions to create directories on the remote PC.
aiwatson
Thanks for the pointer, I had the directory level permissions set ok but not
at the share level. Solve and working fully now. Thanks
