Is it possible for FFS to copy the file path also.
example:
can it recreate the file path on the left to to the right?
file path
FFS copies the (sub)folderstructure present in(side) the left base location to the right base location or vice versa, including all of its contents (as far as not excluded via the Exclude Filter).
So, after the sync, the path relative to the left- and right- base location will be equal per file.
