I wonder how to find the bottleneck:
I compare 2 HDD by content. FFS compares at ~ 90 MB/s. Both devices are utilized only 40-50% by FFS according to Windows Task Manager.
If I copy files from any drive to the internal ssd using Windows Explorer, ~ 175MB/s are reached each.
If I copy files from each drive to the internal ssd using Windows Explorer in parallel, ~ 150 MB/s are reached
(non-cached files, first read access after connecting the drive)
If the files would be fragmented, I would expect slow performance, but drive utilisation should be high.
I made sure to try same as well as different USB controllers for each drive.
FreeFileSync_x64.exe has only 1-2% CPU utilisation, so it is not a single-threading limitation of FFS.
So if neither drive a or b nor usb or cpu is the bottleneck, why does FFS not compare at ~ 150 MB/s ?
Thank you.
USB 3 device not fully utilized?
How fast does FFS actually transfer?
Well, most files are not copied because they are identical. The copy speed depends on file size and fragmentation on both ends, of course.
Currently both drives are synced, but I will check the transfer speed the next time.
