Cannot set directory locks: Would like to IGNORE warning.
PatrickT
I am sync-ing left to write, with read permission but no write permission on the left. I wish to keep it that way (as I'm sync-ing system directories that I do not want to accidentally overwrite/edit).
As reported by many users, if one doesn't have/allow permission access to certain directories, the warning `Cannot set directory locks for the following folders:` is produced.
Can I disable the warning?
Inspection suggests that the directory content is copied as desired. However, a red octagon with a white cross is showing instead of a green tick. I'd like to have a green tick since I'd like to ignore the warning. Possible?
Thanks!
PatrickT
If this feature is not yet implemented, maybe in a future release the icon can be an orange tick: something between the green tick and the red cross. Thanks!
You can disable directory locking (and thus avoid the warning) by setting the LockDirectoriesDuringSync flag to False. See here.
PatrickT
Thanks Plerry, I hadn't thought of that. I understand that directory locking prevents problems when multiple tasks are concurrent. Does that mean when several instances of FFS are running? I usually sync several directories from A to B, are there situations where it wouldn't be safe to disable locking? Thanks!
Directory locking is intended to prevent that multiple instances of FFS (running on the same or on different machines) are simultaneously running a (FFS) sync to/from one and the same location.
Multiple simultaneous FFS instances running a sync to/from non-overlapping locations is never a problem.
PatrickT
Got it, thanks Plerry!
