Hello:
I've thought this through, and I think it's a valid and workable request:
Assuming Realtime Sync gets passed a useful filepath from inotify (or whatever the underlying filesystem watcher is), then could Realtime Sync only process that given filepath (or its parent - whichever seems more robust)?
This would effectively be temporarily passing the filepath as an Include, and * as an Exclude to the appropriate FFS document.
The advantages here would be:
- Much faster sync performance on a large data set;
- The ability for Idle timeouts to only apply to a subset of the 'top-level' folder pair, allowing one subfolder to sync without activity in a different subfolder blocking it.
I know I would personally find this very useful - I hope it's worthy of consideration for inclusion!
Thanks.
[FEATURE REQUEST] Realtime Sync only processes notified file path
