[SOLVED] Multiple versioning folders
rogeriodec
I have 3 source folders with a complex subfolder structure each:
All source files go to the "Original" folder and there, to its corresponding subfolder structures, as should be.
For the versioning, I created a "Versions" folder, which should receive the same folder structure of the "Original" folder:
But for versioning, FFS let me use just one destination folder:
I made a test changing this original file:
After the sync, the file went to the "original" folder correctly:
But the versioned file went to the "root" version folder only (the original source folder structure was not replicated there):
This way, all updated files from all source folders will be mixed in only one versioning folder.
How can I have the same source folder structure replicated to that "user-defined folder"?
It seems you have defined the Versioning folder in the global sync settings (F8).
Try defining the Versioning folder (and other versioning settings) in the local, folder-pair specific sync settings, via the right gear-icon in between each left- and right base location pair.
Mark there that you want to use local settings and change those settings according to need.
rogeriodec
Now it's working. Thank you!
