I would like to exclude everything in AppData except some files/subfolders.
I tried it with the following Rule:
Include:
\Roaming\Microsoft\Outlook\*
exclude:
\Roaming\
\Local\
\LocalLow\
Nothing is synced. Why?
Filter
You're excluding all three main AppData folders
Yes, exactly I would like to exclude everything in AppData except
like explained in the manual:
Example: Exclude a sub folder except for certain files
Set up two folder pairs with the same source and target paths but with distinct local filters:
Folder pair 1; local exclude filter: \SubFolder\
Folder pair 2; local include filter: \SubFolder\*.txt
Hi, Do these filter rules do what you want?
As I understand it FFS builds a list of files first from the include rules, and then removes any files matching the exclude rules. So you can delete the '*' wildcard and specify just the subfolders you want, with no need to explicitly exclude any unwanted parent folders.
Include:
Exclude:
Include:
Exclude:
You (thbenner) do not make your intentions very clear .
If the only thing you want to sync is everything in C:\Users\[User]\Appdata\Roaming\Microsoft\Outlook\, you can simply define your left base location as that, and select/define a corresponding right location.
Everything else in AppData is then automatically not synced.
However, if you want to sync everything in C:\Users\[User], but do not want to sync anything in AppData except in C:\Users\[User]\Appdata\Roaming\Microsoft\Outlook\, then you need to follow the example in the manual (as you seem to suggest to be doing), but then do it correctly.
Define two pairs,
the first pair having a left location C:\Users\[User] and a corresponding right location, in which you use the default local Include Filter (*) and define a local Exclude Filter \AppData\
(this should sync anything in C:\Users\[User], except anything in AppData)
the second left-right pair having the same left and right location as the first pair, for which you define a local Include Filter of \Appdata\Roaming\Microsoft\Outlook\* and an empty or default local Exclude Filter.
(This should sync anything in ...\Microsoft\Outlook\)
You can define local (left-right pair specific) filter settings via the funnel-icon
in between each left-right pair.
Slightly beyond the manual, in above example alternatively you may define two pairs,
the first pair having a left location C:\Users\[User] and a corresponding right location, in which you use the default global Include Filter (*) and define a global Exclude Filter \AppData\
the second pair having a left location C:\Users\[User]\Appdata\Roaming\Microsoft\Outlook\ and a corresponding right location.
As there is no AppData folder inside ...\Microsoft\Outlook\, the global Exclude Filter setting will not exclude said Outlook folder.
Define two pairs,
