I have a custom sync configuration to copy only new files (Item exists on left
side only) - I want to copy files from the source that do not exist in the
destination. When I run the sync, it gives a warning about a file exists on
the left side that is a different size as a file on the right (which in my
scenario is expected). I've selected to ignore errors expecting it to continue
uninterrupted, but I continue to get the same warning for each file in the
source that exists in the destination.
I recognize that in the Compare settings, I only have 2 options: "File time
and size" or "File content". Perhaps there should be a 3rd option, "File
Exists"? Is the File Compare what's causing the sync issue? Alternatively, if
I could have an "Ignore" option for the Conflict category like I have with the
other categories it would result in the intended behavior?
Copy only new files generates warning
What warning do you get exactly? And what is your custom sync configuration?
