Can't ignore a directory tree but includ a single file
Lunix
I created include and exclude lists that contain these:
Include:
\PPL\PPL_Index.htm
Exclude:
\PPL\
But I can't get FFS to include that single file (PPL_Index.htm). It just ignores it.
What am I doing wrong here?
Set to this \/
Remove the star from include and remove the exclusion.
Include:
\PPL\PPL_Index.htm
Exclude:
Lunix
I should've been more clear- I have lots of other files and directories that I need to copy in this job (and it's working well, except for this file). But from this one directory (PPL), I just want the one file and want to ignore the rest of the directory and subdirs. Your suggestion would work if this is the only file in the sync job. I didn't make that very clear.
Look at the "Exclude a sub folder except for certain files" example in the FFS Manual section on Excluding items.
Lunix
At your suggestion, I examined that page. I had already tried the technique there using wildcards only for the filename. But I tried slightly differently, as shown on that page- it failed too.
Then I realized it first said to set up the folder pairs twice with different exclude and include filters. And it worked perfectly.
Thank you
