Forgive me if this has been asked before, or I'm misunderstanding the "time span" option, but...
I get the impression that if you're sync'ing 2 folders, even when using indicating a "Time Span", that there is a comparison of ALL files in the 2 folders, is this right?
If the destination folder is down a slowish link, or hosted on a slower system (think Raspberry Pi V1... don't ask), then the comparison takes quite some time, when you only want to actually copy files changed TODAY for example.
If this is the case and I haven't misunderstood, then the app may benefit under such circumstances to find the files which are within the time span and then do a compare. If I am missing something here, I'd be most grateful for your advice.
Compare by time
