Can you please either eliminate, allow me to control, or drastically increase the timeout on the:
CURLE_OPERATION_TIMEDOUT: Operation too slow. Less than 1 bytes/sec transferred the last 15 seconds
Best case would be to simply allow for retries, perhaps show a retry counter. But this stops my file syncs at least once an hour - I've been trying to copy 100GB to my google drive using FreeFileSync for 8 days now. I can do it in a couple of hours when I drag/drop the files directly. This timeout makes FreeFileSync unusable for google drive filesyncs.
If there is a workaround, please let me know. Thanks!
Google drive filesync timout
I found what I was looking for!! I am able to set the timeout duration AND the retry count. However, this does not work when a file already exists - it could retry all day, it isn't going to help... however, there is an 'ignore errors'... which, works well - you can still see the errors at the end.
@whalehead99: You say you found a place to set the timeout duration AND the retry count. Could you explain where you found those settings?
