Not syncing everything
mgb620
I'm trying to sync music folder files and for some reason, filesync won't sync the album art (jpeg) files, just the music files. Can someone tell me why? Thanks in advance.
Perhaps *.jpeg files are excluded per the Exclude Filter (F7).
If so, remove that line from the Exclude Filter rules.
Gianni1962
Depending on the software that creates and manage the album art files, those files can be hidden so you should select the option to show hidden files in the Windows File explorer.
therube
(FFS does not ignore hidden (or system...) files - that I am aware of.)
