When trying to compare drive(s) with drive mapped by NetDrive client
([http://www.netdrive.net/).](http://www.netdrive.net/.)) It causes quite a
number of "Windows Error Code 2" errors. However, comparison works perfectly
when using standard Windows mapping.
Windows Error Code 2 with NetDrive client
The directories for which this happens are empty, right? With empty I mean
issuing a "dir" in the console not even brings up "." and ".." entries?
The problem is "FindFirstFileEx" returns with ERROR_FILE_NOT_FOUND in both
cases where a directory does not exist and when it didn't find a single child-
entry.
Former is an error, while latter is not, alas "FindFirstFileEx" doesn't bother
to make this fundamental distinction.
FFS let's this error propagate, since in general a directory always has "."
and ".." entries, so the error must mean that the directory is not existing.
Exceptions: Root directories and NetDrive.
entry.
just double checked, no they are not empty but containing Asian characters.
This is not a analytical result because I have switched to another solution
and lazy to dig out what the problem is. Thanks for your respond!
It seems to be a NetDrive bug. When trying to create a new file on an FTP
server via NetDrive using some non-ANSI characters Windows Explorer returns
"file not found" instead of "character not supported", "internal failure",
whatever it is it's certainly not "file not found". FFS probably hits the same
wall.
wall.
Hi Zenju,
You're very good in supporting the software. I'm using Netdrive to map my SFTP as a drive. I'm facing the same problem as raiko, but in my case whenever the source folder is empty, or containing only .java files.
I don't think this is bug from NetDrive because I can copy the folders/files using explorer.
I'm using FreeFileSync 5.10 and NetDrive 1.3.2.0
Thanks for the great software.
FreeFileSync supports SFTP directly as of version 7.2.
