cannot save more than one configuration file
bradles
I'd like to be able to save more than one configuration file (like in the 1st screen shot on SourceForg). Unfortunately, I can only seem to save one configuration file. I am trying to do this on Ubuntu 12.04. Im pretty sure I was able to save multiple configuration files On the windows version and so I'm at a loss as to why Ubuntu doesn't seem to allow it. I have to save over my original config file to try and add a different sync setup. I know you can add multiple syncs to the one config but I actually want to have mine separated out into different config files.
Is this a bug?
I installed FFS from the repositories...is it possible that it is just an older version? If so, how do I update it to the lateset version as I couldn't see any ubuntu 12.04 packages in the downloads?
Brad
