Suggestion - Enable Sort Disk & Folder List
When adding/updating (USB)disk/folder sets a long list can become unsorted making it difficult to see which ones have been added already. Suggest being able to click the header to sort alphabetically.
(Depending on the number of sets you are adding, you can drag the "splitter" between the folder sets & the Compare results box, down, temporarily even, to give you greater visibility to the list of folder sets.)
