(First, many thanks to developers for FreeFileSync)
Not sure this improvement has been requested. Sorry if it is a duplicate.
I often found annoying there is no "Delete the configuration file on disk" command in the popup menu,
over the configuration file list. And there is a limited capability for managing the Job files in FFS.
Currently, we have "Hide configuration" (the job is hidden from the job list) only.
But I would like to have more commands, like "Delete on disk" and similar.
For example, I made sometimes a duplicate of Job file from the filesystem, then I open it with "Open", and modify the configuration. Other times I want to delete the Job old-file, and I need to browse again the filesystem for this simple operation. Etc.
It would be more easy to have all these basic operations on configuration files from FFS itself.
___
Ideally, we could have a submenu (similar to "Background color") so we get all filesystem options.
So when we right-click on a Job configuration, the popup menu would contain a option + sub-options:
Menu:
Rename
Manage... >>
Background color...>>
Sub-menu from "Manage....":
> Hide from interface
> Delete from disk .......................... (with confirmation dialog + Button to open Explorer)
> Duplicate Job (on disk AND interface)... (with new-name dialog, using #1 appended to previous name)
> (etc.)
> Add Job description .........................(this request appears in a recent topic. I agree.)
Something intuitive and flexible to allow operations that otherwise require to go to Explorer-
Again, many thanks for your attention !
Request: more options on Job configuration files
Added for the next version:
New config file context menu option: Show in file manager
Great ! Many thanks, Zenju,
Also added for the next version:
New configuration context menu option to delete from disk
