It would be nice to display information not only from the full amount of synchronization, but also about its structure, namely: the amount of moved, the amount of renaming, the amount of deleted, the amount of created (and maybe something else). When you see only the total volume, it is confusing, since it is difficult to estimate the time required for synchronization (moving, renaming and deleting is much faster than copying).
(Google Translate).
Displays the structure of the sync volume
You can select which items to show at the bottom of the window. The size changes with those show/hide panels
Thanks! I'll try.
