MIRROR backup - Recycle Bin
bobmane
I always use MIRROR backup - sometimes on Mac OSX side and sometimes on Windows bootcamp....but to the same backup drive from the same source drive.
I have an issue where somehow some Recycle Bin related files wont delete. I suspect something happened while jumping between OS's.
Anyway...See image...Any solution?
Delete them manually from Finder or File Explorer?
bobmane
It is phantom files
You'll probably need to do it from admin command prompt
bobmane
Do you know the command?
You'll need to get into that directory from and admin command prompt. You 'cd' to get there:
"cd /d J:\OT"
Then "del /f *.ffs_temp"
You may need to run:
"del /ah /f *.ffs_temp"
