Glitch on Sync/Mirror <Item not existing>
t0ma5
Hi guys. I use FFS to sync/mirror two Google Team Drives (AKA Shared Drives) and it used to work perfectly, but not anymore, this is my problem:
FFS was working just fine until two days ago when out of the blue, without changing any configuration or setting, FFS stopped reading files correctly in both folders (source and destination) so it tries copy and delete files without any need for it.
FFS claims that many files don't exist on both sides by displaying this message: <Item not existing>
I open the team drives on my browser and I can see all the files that FFS can't see, I can open them and download them without a problem, but FFS says the items are not there.
Also it reads the destination folder with mistakes claiming some files/folders don't exist and it need to copy them (but again, I can see/use those files with my internet browser). So it read both (source and destination) wrongly and suggests actions that are not necessary to perform.
The folders in question (source and destination) have about 1.5TB of data. I am using Windows 10 and FFS v11.3 (same problem with v11.2)
Thanks for your help
EDIT: A quick fix is to delete the DB file in
C:\Users\YOU_NAME\AppData\Roaming\FreeFileSync\GoogleDrive
and run all the scans again to rebuild a new DB that works for some time until it gets corrupted again. Rinse and repeat.
therube
the source folder
Is that a "real" (i.e., not some "virtual") local folder on your HDD?
t0ma5
the source folder
Is that a "real" (i.e., not some "virtual") local folder on your HDD? therube, 02 Nov 2020, 17:20
no, both folders are TEAM DRIVES and it worked just fine for weeks, no problem at all (until now).
I even tried GoodSync to see if I get the same reading errors and that's not the case, only with FFS
t0ma5
UPDATE: Re-installing FFS solved the issue. I reloaded my saved profiles (untouched) and they worked again as expected. So it was not a miss configuration but some sort of glitch...
t0ma5
It keeps happening, after certain time FFS starts to give errors and the only way to "fix" it is re-installing :(
UPDATE: Re-installing FFS solved the issue. t0ma5, 02 Nov 2020, 22:45
By reinstalling you deleted the local google drive database file that apparently got corrupted. You could achive the same effect by opening the Google Drive settings in FreeFileSync, "Disconnect" and "Add connection".
The real question is why the database file got corrupted in first place. Are you able to simplify and replicate this issue? If yes, I can have a look and make sure it gets fixed.
t0ma5
The real question is why the database file got corrupted in first place. Are you able to simplify and replicate this issue? If yes, I can have a look and make sure it gets fixed. Zenju, 12 Nov 2020, 17:37
Thanks, I will try your tip next time it happens. And no, I can't replicate it. It seems to happen after X time using the application :(
I don't think this is a random bug. Most likely there is a specific sequence of file operations happening on the shared drives that send out a number of change notifications that are not correctly processed by FFS. How this could be I can't imagine, so a repro is essential. Alternatively, full access to a Google Drive account that exhibits the bug might do, but I understand this is probably not feasible.
jpgill86
I have experienced issues with Google Drive a few times like those described by t0ma5, though I was using a Google Shared Drive as a backup for local files, rather syncing two Drives.
The first time it happened, it was very painful and nearly cost me data, since I had a nightly batch script running two-way synchronization. Gigabytes of files were just deleted one day! Luckily, I had other backups! I changed the two-way sync mode on my nightly script to a one-way update instead; this worked fine initially, but sometime later duplicates of files appeared in Drive, since it apparently thought those files weren't on the Drive any more. I deleted those duplicates by hand and wondered what was going on.
Apparently I'm a slow learner, because I let it happen a third time in one-way update mode, so duplicate files appeared in Drive again. When I asked it to do a comparison in two-way mode, it showed that it thought many of the Drive files were deleted, and it wanted to remove them from my local machine. Like the first time, if I had still been using two-way mode for my nightly script, I would have lost files.
A little frustrated, I just walked away from it for a couple weeks, letting those duplicated files sit there. But today I felt like trying to solve the problem, and I quickly stumbled upon this thread.
Following Zenju's suggestion (thank you for this software by the way; despite this post, I absolutely love it, and am already a regular donor!), I tried disconnecting and reconnecting my Google Drive account. When I attempted a two-way comparison again, apparently a new sync.ffs_db was created in the Shared Drive. I received this error:
"Cannot open file <...>\sync.ffs_db. The name sync.ffs_db is used by more than one item in the folder."
Indeed, there were now two copies of the file in the Shared Drive.
I then deleted the newer copy of sync.ffs_db and reran the two-way sync. This time, there was no error, and the file comparison gave the expected results, albeit somehow ignoring the duplicated files on Drive.
The following may be an independent problem, or it might be caused by the changing sync.ffs_db file:
After getting that to work, the file comparison helped me realize that some files needed to be deleted from the Shared Drive; they were mistakenly placed there by a collaborator. As expected, these files were showing in my two-way comparison as being ready to be copied locally. Since I did not want to keep them, I deleted them in the Shared Drive manually, but when I re-ran the comparison, it still claimed these deleted files were in the Shared Drive, ready to be synced. I tried emptying the Shared Drive's trash, but that made no difference. When I tried to actual perform the sync (not just a comparison) on the non-existent file, I got this message:
"Cannot read file "<name of my file>. File not found: <Google Drive id for the file>"
So, next I tried deleting the old sync.ffs_db in Drive also. Now there were not two or one database files, but zero. This had no effect on the comparison, and a new sync.ffs_db was not immediately created in its place.
Finally, I disconnected and reconnected my Google Drive account a second time. This time, the comparison refreshed accurately, and a new sync.ffs_db was created.
As of this writing, all is working as expected. However, since I anticipate there being another issue like this in the future, I have disabled all automatic nightly backups to Google Drive and will monitor for this problem in the future whenever I run a manual backup. That way, I can avoid losing files with a bad two-way sync, or duplicating files with a bad one-way update.
But, of course, I'd love to see the problem identified and fixed! Unfortunately, I don't know how to reproduce it consistently. If it would be helpful to, say, preserve and share my sync.ffs_db file when this happens next before doing the disconnect-and-reconnect workaround, I'm happy to try that.
P.S.: I always try to keep my installation of FreeFileSync up-to-date. Presently, I'm at version 11.4.
t0ma5
Hi jpgill86!
I have encountered this problem many times already, the more I run syncs the more often it happens.
For the time being my work-around is to delete the DB file in
and run all the scans again to rebuild a new DB that works for X time until it gets corrupted again.
I have to check every scan result manually before going ahead with the sync to prevent mistakes from happening as you described.
@jpgill86:
These seem to be different issues than what t0ma5 was describing, which is "FFS reporting <Item not existing>, when the file in fact exists".
I deleted them in the Shared Drive manually, but when I re-ran the comparison, it still claimed these deleted files were in the Shared Drive, ready to be synced.jpgill86, 17 Dec 2020, 23:29
This is "normal" for Google Drive. It takes a short moment until Google Drive reports changes that happen externally (= outside of FFS), such as file deletions.
externally (= outside of FFS). jpgill86, 17 Dec 2020, 23:29
Google Drive allows multiple items that have the same name. So it can happen if two FFS instances are syncing the same folders more or less at the same time that both try to update the sync.ffs_db file:
1. both instances delete the old sync.ffs_db (one succeeds, the second skips with nothing to do)
2. both instances create a sync.ffs_db
The proper solution for both such issues is some form of folder locking that makes sure only one FFS instance is ever accessing a Google drive folder at a time. This is implemented via the sync.ffs_lock file for local drives and network shares. Unfortunately no such mechanism exists for Google Drive.
KinsleyProk
maybe you would take a look to GoodSync or Gs RichCopy360 , I think you will not face this problem with these tools , search both
t0ma5
maybe you would take a look to GoodSync or Gs RichCopy360 , I think you will not face this problem with these tools , search both KinsleyProk, 06 May 2021, 08:45
Those options are painfully slow compared to FFS
t0ma5, 02 Nov 2020, 14:52
Is there some way to reproduce this, or some test account that I could analyze from my end?
t0ma5
Is there some way to reproduce this, or some test account that I could analyze from my end? Zenju, 06 May 2021, 10:36
This is exactly what I do:
• I have 3 SHARED DRIVES on my Google Drive, let's call them A, B and C
• I manually upload content to A on daily basis. Mostly folders with a few large video files inside (2-5GB)
• I sync A to B and C using FFS and it works without a problem, for some time.
• After a while, something goes wrong and FFS acts as if B and C were empty, it wants to copy everything from A to B and C again. But on the web-browser I can see B and C are not empty, all the files are there but are somehow ignored by FFS
• To fix it I have to delete "mymail@gmail.com.db" and re-scan everything again. Then it works fine for some time until the problem appears again.
• After a while, something goes wrong and FFS acts as if B and C were empty t0ma5, 06 May 2021, 10:45
This is the interesting part. FFS apparently receives change notifications from Gdrive that report the files as being "removed". Question is: Is this the case and if yes what exactly triggers these change notifications? E.g. is the shared drive disconnected, and connected again, or some permission/owner change of the shared drive or one of these folders. Or something else?
t0ma5
E.g. is the shared drive disconnected, and connected again, or some permission/owner change of the shared drive or one of these folders. Or something else? Zenju, 06 May 2021, 12:37
No idea but I can tell you that I use those extra SHARED DRIVES as mirror backups ONLY. No other app has access to them in any way. The only changes I make to drives B and C are those made by FFS sync, absolutely nothing else. I don't even access them via web browser until FSS tells me they are empty and I go and check manually.
In case you somehow manage to reproduce this with as *few steps as possible*: Try to send me the list of change notifications that FFS is receiving as follows:
1. Get the current "start page token". This represents a current snapshot of your Google Drive state: https://developers.google.com/drive/api/v3/reference/changes/getStartPageToken
2. Reproduce the issue of FFS not seeing an item, although it is there and note its ID, which is part of the share link.
3. Get the list of changes since step 1: https://developers.google.com/drive/api/v3/reference/changes/list
No idea but I can tell you that I use those extra SHARE DRIVES as mirror backups ONLY. t0ma5, 06 May 2021, 12:46
Shared drives means someone else is also having access to these drives? Maybe they are doing something with it?
t0ma5
Shared drives means someone else is also having access to these drives? Maybe they are doing something with it? Zenju, 06 May 2021, 12:56
Yes and No. Let me explain.
The SHARED drives belong to me, I gave no access to anyone. Of course the Google Suite admin of each organization has access to them. I see what your logic is here, but the problem with FFS saying that those drives are empty happen at the same time with all the SHARED DRIVES administered by different organizations. This leads me to believe the issue is from FFS' side.
Whatever it is, in order to get it fixed we either need steps to reprocudce, or at least the list of change notifications (which hopefully and likely give a clue).
We could even do this retroactively, since Google Drive change notifications are persistent. So the next time you encounter the situation that a file exists but is not shown in FFS, don't touch anything, but retrieve its ID. We'll then try to extract the change notifications via the Gdrive v3 API as outlined above.
t0ma5
We could even do this retroactively, since Google Drive change notifications are persistent. So the next time you encounter the situation that a file exists but is not shown in FFS, don't touch anything, but retrieve its ID. We'll then try to extract the change notifications via the Gdrive v3 API as outlined above. Zenju, 06 May 2021, 13:17
Sorry, the instructions don't mean much to me, there are many fields to complete and I have no idea. I don't know what do with this result
 "kind": "drive#changeList",
 "newStartPageToken": "341XXX",
 "changes": []
Do you have a file ID for a file that is not shown as existing in FFS?
t0ma5
Do you have a file ID for a file that is not shown as existing in FFS? Zenju, 06 May 2021, 13:29
not now since I "FIXED" the database yesterday for the last time. In a few days I will face the problem again. What exactly should I do then? Happy to send u the logs but I need further instructions, pls! :)
No prob. I'll give you further instructions once we're there.
jpgill86
Hello again! I've been following along. :-)
Thank you Zenju for replying to my earlier post back in December. While I agree that I had multiple symptoms, suggesting possibly multiple issues, I still think that what t0ma5 has been describing is among them.
This has continued to occur from time to time, unpredictably, for me since I last posted in December, with files occasionally being identified by FFS as removed from my Shared Drive despite them being there. In fact, it just happened for two files.
My approach for dealing with this has been not to delete the database file, as t0ma5 has suggested, but to just disconnect and reconnect to my Google account. I think that has worked every time for me.
I read this thread this morning and hoped to be able to contribute next time it happened to me, so when a few minutes ago FFS reported two files as deleted, I wanted to investigate it a bit more. I checked the timestamps on the supposedly deleted files, as reported by Google Drive, and noticed that the creation dates were April 21, despite the fact that the two files are much older and haven't been touched since before that date. In fact, the last modified dates precede the creation dates.
Intent on getting a file ID, as Zenju suggested, I clicked on the files in my browser to open them, so that I could extract the ID from the URL. Not only did this update the last opened date on Google Drive, but it also fixed the comparison in FFS, so that the files were no longer reported as deleted. I did this for the two files one at a time, and they were fixed one at a time.
I went ahead anyway with using the Google API to retrieve a changes list, but I guess that since my page token was generated after I had inadvertently fixed the problem files and had made no other changes, the list was empty.
Just to see what would happen, I also tried the Files: get API using the file ID of one of the two files, but this didn't provide anything illuminating (just these fields: kind, id, name, mimeType, teamDriveId, driveId).
jpgill86
It's happened again! And this time I haven't fixed it yet, so instructions on what to do next are welcome.
I just ran a comparison on a different folder in the Shared Drive, and I'm seeing 5 files with erroneous comparisons. I also ran a comparison on a different Shared Drive (owned by the same organization), and I'm seeing 14 files with bad comparisons there too.
These are by no means the whole file sets. The files indicated as changed seem to just be a random selection, though in one case it's all files in a small folder, along with the folder itself. Curious to see if the issue with the folder was the directory itself or each file within, I merely opened the folder in my browser, and that cleared up the bad comparison for that folder and its contents.
I should correct something I said in my last post. I repeatedly said that FFS reported the files as deleted. However, I had my comparison mode set to Update, saw that it wanted to push the local files to the remote, and assumed that if I switched to Two-Way it would say that the files were deleted. I just tried switching my comparison to Two-Way for these new cases, and it still wants to copy local files to the Shared Drive, as if they are brand new and are absent from the Drive (even though they are not), rather than delete the local files because it thinks the remote's copies were deleted. It's as if those files on the Shared Drive are invisible to FFS, and it has forgotten they were previously copied there, so FFS thinks it needs to copy them now.
Anyway, I will wait to fix these problems (I would normally dis- and re-connect to my Google account), and I look forward to some instructions on how to help further.
I'm too busy right now to respond in detail, but maybe this highlevel overview is enough and you can figure out the missing parts:
1. get the "start page token" that represents the current state:
viewtopic.php?t=7827&p=29595#p29547
2. get the list of changes (also explained by the link)
as input, use the start page token and make it "somewhat" smaller
how much? I don't know, but you can test this and see what you get for different values
Goal is to make it small enough to get change notifications that include the one that lead FFS into assuming a particular file (note the ID!) was deleted, but large enough to not get flooded with irrelevant changes.
Use these parameters for the "list" command:
pageToken: from step 1
fields: kind,nextPageToken,newStartPageToken,changes(kind,changeType,removed,fileId,file(trashed,name,mimeType,ownedByMe,size,modifiedTime,parents,shortcutDetails(targetId)),driveId,drive(name))
includeItemsFromAllDrives: true
pageSize: 1000
spaces: drive
supportsAllDrives: true
jpgill86
Thanks for the guidance Zenju!
I decremented my page token just enough to get changes that are timestamped before today, for a total of 20 changes. I've attached the JSON output.
There is a suspicious string of changes with identical timestamps from earlier today (2021-05-06T16:15:11.188Z). I'm 99% sure this was a few hours before I used FFS today (I understand this is UTC time and have accounted for time zones and daylight savings time), but one of these changes was to sync.ffs_db, so perhaps I'm mistaken. The other file changes with that timestamp correspond exactly to my list of files reported by FFS as missing from the Shared Drive (except for one extra file listed among the changes that is not flagged by FFS). All have the "removed" parameter set to false.
Since FFS seems to think that the files don't exist on the Shared Drive (rather than that they were deleted -- I assume in that case a Two-Way sync would suggest deleting my local files), would it be better to query for the Shared Drive's file list, to see if the files are unlisted? Is that a plausible way that FFS would think the files don't exist? Or does it only comb the change list? That would seem like an inefficient way to determine if a file was present or not, since you would have to search the entire history.
change-list.txt
(9.15 KiB) Downloaded 2676 times
That's a good start. A few remarks:
You also need to set the "fields" parameter as mentioned earlier. Otherwise you won't get all the detail fields that FFS is seeing. For example, there's not only the "removed" field, but also a "trashed" field, and a "parents" field (removing a parent is similar to deletion).
Also. An item can be deleted implicitly when one of its parent folder is deleted. So it's important not only to search for a particular item ID in the changes list, but also all the IDs of parent elements and see what's changed for them.
jpgill86
You also need to set the "fields" parameter as mentioned earlier. Zenju, 07 May 2021, 06:26
Oops! >_<
Here's another JSON output, this time with the fields you listed. I extended your list a bit by adding fields that appeared among the default fields, so that the new JSON output is a superset of the old (in particular, the "time" field needed to be added to see that suspicious timestamp). I also added "createdTime". For the record, these are all the fields I used:
kind,nextPageToken,newStartPageToken,changes(time,type,kind,changeType,removed,fileId,file(kind,id,trashed,name,mimeType,ownedByMe,size,modifiedTime,createdTime,parents,shortcutDetails(targetId),teamDriveId,driveId),drive(name))
The new fields that appear in this version of the JSON output but not the first are "createdTime", "trashed", "parents", "modifiedTime", and "size". For every one of the changes with the suspicious timestamp mentioned earlier, "trashed" is set to false. Nothing else stands out as unusual to me.
change-list-2.txt
(13.31 KiB) Downloaded 2757 times
jpgill86
Also. An item can be deleted implicitly when one of its parent folder is deleted. So it's important not only to search for a particular item ID in the changes list, but also all the IDs of parent elements and see what's changed for them. Zenju, 07 May 2021, 06:26
By this do you mean that, although the new JSON output I just posted has "trashed" set to false for all changes with the suspicious timestamp corresponding to files indicated by FFS as missing, their parents (or their parents' parents, etc.) might have been trashed? Do I need to perform a file query for each parent?
Here's a screenshot of the bad two-way comparison in FFS, which might make deciphering the JSON a little easier. Again, all of these files are in fact still on the Shared Drive, though FFS seems to think they are not.
jpgill86
By the way, I have some familiarity with the Google Drive API already. I created a Python application with a feature that uses the API (via PyDrive2) to download files by path, rather than file ID, so I know a bit about traversing the file tree.
Anyway, given some specific details on how FFS decides when files are missing from the server, perhaps I would be able to do some deeper digging.
The source is in \Source\afs\gdrive.cpp
After an initial traversal, FFS *only* uses Google's change notifications ("list") to update the file state.
So whatever the reason why a file is missing (*), it must have been communicated via change notifications.
*) To be verified: how did you conclude the file is really *existing* at this Google Drive path? It's possible FFS is right, and the file was moved somewhere else.
Having a look at the first file:
<shared drive: 0AFnJZoCV2a6RUk9PVA>
-> "Data" <folder: 1RpF7RgJmgYUQ-6r5R3IxoMRnzM5YMeK->
    -> "Animal-10_35g_2021-01-18" <folder: 1eIGNDUMJCr-E0AneocuL-8G8ivUojddD>
        -> "Animal-10_35g_2021-01-18 001 EPOCH-ENCODER.csv" <file: 12dG_uscX47wmEewXS1cvl7KK3Y6mxKKz>
You're syncing against the "Data" folder of your shared drive.
According to the change notifications you provided above, the path on Google drive is:
<shared drive root>/Data/Animal-10_35g_2021-01-18/Animal-10_35g_2021-01-18 001 EPOCH-ENCODER.csv
Can you check the IDs of the parent folders and the .csv file on your Google Drive account and see if they match?
There's also a removed file or folder (ID 1Hb4S8DDn0kEleVem3n4-pul4FGobhAhx) at "2021-05-06T23:48:19.720Z", wondering what this was..
jpgill86
*) To be verified: how did you conclude the file is really *existing* at this Google Drive path? It's possible FFS is right, and the file was moved somewhere else. Zenju, 09 May 2021, 12:02
I think I can verify that files with these names exist at these paths by browsing to the containing folder in Google Drive in my browser:
The parent (folder) ID is visible in the address bar. I can check the file ID by right-clicking and choosing the "Get link" option:
However, if I were to double-click on the file to open it, it would display as expected (a preview of the spreadsheet would be displayed), and then the file would drop out of the list of files reported by FFS as missing from the Shared Drive. Could we take advantage of this odd effect by looking at the change list right after I open a file, causing it to be cleared from the list?
Can you check the IDs of the parent folders and the .csv file on your Google Drive account and see if they match? Zenju, 09 May 2021, 12:04
As you can see from the screenshots above, the IDs for the CSV file and the "Animal-10_35g_2021-01-18" folder match those that appear in the changes list. I also checked the "Data" folder ID and shared drive root ID, and these also match.
There's also a removed file or folder (ID 1Hb4S8DDn0kEleVem3n4-pul4FGobhAhx) at "2021-05-06T23:48:19.720Z", wondering what this was.. Zenju, 09 May 2021, 12:16
I'm not certain, but I think that was something I did intentionally while composing a post for this thread on Thursday. I may have created and then deleted a file as a test. That change does not appear in my first JSON file (the one with too few fields), so it must have been something I did before generating the second.
So whatever the reason why a file is missing (*), it must have been communicated via change notifications. Zenju, 09 May 2021, 12:02
Gotcha, I think I get it now. Is it possible my JSON file does not go far back enough in time for us to see the most relevant changes, and the changes with the suspicious timestamp that I've been focusing on are a red herring?
I think I can verify that files with these names exist at these paths by browsing to the containing folder in Google Drive in my browser: jpgill86, 09 May 2021, 23:05
Looks good. The file IDs and parent-child folder relations match what's listed in the change notifications.
Considering that for example the item "Animal-10_35g_2021-01-18 001 EPOCH-ENCODER.csv" is not removed, not trashed, and it's parents structure is intact, it should be listed as existing on the right hand side of download/file.php?id=1900&sid=1510e118cfc2f5ee3fc8a33dd166cc2c
Except (for completion): The screenshot doesn't explicitly show that the right hand side really is the shared drive, and the left side is the local drive.
However, if I were to double-click on the file to open it, it would display as expected (a preview of the spreadsheet would be displayed), and then the file would drop out of the list of files reported by FFS as missing from the Shared Drive. jpgill86, 09 May 2021, 23:05
Double-click where? In FFS or in Google Drive? Double-clicking an item in FFS will open the browser and navigate to Google Drive without preview.
Could we take advantage of this odd effect by looking at the change list right after I open a file, causing it to be cleared from the list? jpgill86, 09 May 2021, 23:05
I'm assuming by "cleared from the list" you mean it is shown as existing in FFS when you click on the equal(=) button? This means FFS has received new change notification as a result of your double-clicking.
What kind of change notifications? We can find out!
1. https://developers.google.com/drive/api/v3/reference/changes/getStartPageToken
2. double-click...
3. getStartPageToken again, this should yield a new token => this shows that indeed changes occurred
4. retrieve list of changes by entering the token from 1.: https://developers.google.com/drive/api/v3/reference/changes/list
Is it possible my JSON file does not go far back enough in time for us to see the most relevant changes, jpgill86, 09 May 2021, 23:05
I don't think so. The changes shown in viewtopic.php?t=7827&start=30#p29629 should be enough for FFS to assume an existing file at <shared drive root>/Data/Animal-10_35g_2021-01-18/Animal-10_35g_2021-01-18 001 EPOCH-ENCODER.csv
and the changes with the suspicious timestamp that I've been focusing on are a red herring? jpgill86, 09 May 2021, 23:05
The change notifications at 2021-05-06T16:15:11.188Z match exactly the 14 items shown missing on your screenshot download/file.php?id=1900
This could be more than a coincidence.
Also noteworthy:
• there's an "Animal-10_35g_2021-01-18 002.axgd" file also changed at 2021-05-06T16:15:11.188Z, not shown on your screenshot => maybe it is one of the equal ("=") files? Or excluded via filter?
• the two files "Animal-10_35g_2021-01-18 001.axgd" and "Animal-10_35g_2021-01-18 002.axgd" are existing twice on your screenshot: download/file.php?id=1908
Current working theory:
I believe Google Drive is delaying the sending of change notifications. That could explain all these symptoms, but this theory first needs to be verified:
A delay of sending change notifications is possible when manually deleting a file via the browser interface. It can take a while (sometimes multiple minutes!) before FFS "sees" the deletion, even though it is polling Google Drive change notifications ("list") repeatedly. I've seen this Google Drive "delay" myself (... it could almost be called a bug...), and also:
After getting that to work, the file comparison helped me realize that some files needed to be deleted from the Shared Drive; they were mistakenly placed there by a collaborator. As expected, these files were showing in my two-way comparison as being ready to be copied locally. Since I did not want to keep them, I deleted them in the Shared Drive manually, but when I re-ran the comparison, it still claimed these deleted files were in the Shared Drive, ready to be synced. I tried emptying the Shared Drive's trash, but that made no difference. jpgill86, 17 Dec 2020, 23:29
So maybe in the current case with shared drives, access to some files is lost temporarily. Google Drive API's "list" will report deletions, FFS sees these changes and dutifully removes these files from its Google Drive database (.db) in the "GoogleDrive" subfolder.
After a while, access is restored back to normal, but the Google "list" API does not report this change (yet), which one could call a bug (or Google could call it a "performance optimization"). Only *after* you physically access a file, the "list" API finally returns the list of change notifications that make the files reappear. Evidence:
Intent on getting a file ID, as Zenju suggested, I clicked on the files in my browser to open them, so that I could extract the ID from the URL. Not only did this update the last opened date on Google Drive, but it also fixed the comparison in FFS, so that the files were no longer reported as deleted. I did this for the two files one at a time, and they were fixed one at a time. jpgill86, 06 May 2021, 19:44
t0ma5
what would be the best work-around for this problem?
jpgill86
Except (for completion): The screenshot doesn't explicitly show that the right hand side really is the shared drive, and the left side is the local drive. Zenju, 10 May 2021, 14:10
A fair point! I was lazy and cropped out the private information, rather than blurring it. Here is another version showing that the local and remote sources were on the left and right, respectively, and that the comparison mode was two-way.
Note that there is one fewer file here compared to the previous screenshot. This is because I intentionally caused the animal 13 file to drop out of the list by opening it on Google Drive in my browser.
Double-click where? In FFS or in Google Drive? Double-clicking an item in FFS will open the browser and navigate to Google Drive without preview. Zenju, 10 May 2021, 14:10
I meant in Google Drive, from a web browser, as could be done from this screen: download/file.php?id=1908. Doing so will open a preview of the CSV file, like this:
Opening this preview will cause the file to drop out of FFS's list of files needing to be synced, suggesting it has become aware of the file's presence on Google Drive.
I'm assuming by "cleared from the list" you mean it is shown as existing in FFS when you click on the equal(=) button? Zenju, 10 May 2021, 14:10
Yes, that's right. Here's the animal 13 file, previously thought by FFS to be in need of copying to the Shared Drive, but now recognized as being there already after I opened the CSV preview in my web browser:
This means FFS has received new change notification as a result of your double-clicking. What kind of change notifications? We can find out!
2. double-click...
4. retrieve list of changes by entering the token from 1.: https://developers.google.com/drive/api/v3/reference/changes/list Zenju, 10 May 2021, 14:10
An excellent experiment. Here is the entirety of what I got after double-clicking on the animal 15 file:
 "newStartPageToken": "13230",
 "changes": [
   "kind": "drive#change",
   "type": "file",
   "changeType": "file",
   "time": "2021-05-11T00:55:28.000Z",
   "removed": false,
   "fileId": "1t7fwQXTzyP4gADxqyncWnrLm9YfomSIF",
   "file": {
    "kind": "drive#file",
    "id": "1t7fwQXTzyP4gADxqyncWnrLm9YfomSIF",
    "name": "Animal-15_61g_2021-02-12 001 EPOCH-ENCODER.csv",
    "mimeType": "text/csv",
    "trashed": false,
    "parents": [
     "1V6Dx7X9cUc136ZOWr3erY-lc0k8L_x8Y"
    "createdTime": "2021-04-21T20:41:01.142Z",
    "modifiedTime": "2021-04-21T20:35:47.000Z",
    "teamDriveId": "0AFnJZoCV2a6RUk9PVA",
    "driveId": "0AFnJZoCV2a6RUk9PVA",
    "size": "5397"
The timestamp "2021-05-11T00:55:28.000Z" correctly identifies the time when I did the double-clicking. Other than that, this one change list entry is identical to the one found in my previously shared JSON output, which had that suspicious timestamp.
Upon opening the preview, the Last Opened timestamp was updated:
I guess the change list entry copied above refers to an update to the Last Opened timestamp. However, this JSON output doesn't make that clear. Are there perhaps other fields I can query to show that this change list entry is describing an update to the Last Opened time? And if I query the same fields for the older suspicious entries, might we find out what caused them?
Also noteworthy:
• there's an "Animal-10_35g_2021-01-18 002.axgd" file also changed at 2021-05-06T16:15:11.188Z, not shown on your screenshot => maybe it is one of the equal ("=") files? Or excluded via filter? Zenju, 10 May 2021, 14:10
I can see that it is indeed one of the equal files. It is not excluded by a filter. For whatever reason, this one file out of all those with that suspicious timestamp is correctly identified by FFS as being present on the Shared Drive.
• the two files "Animal-10_35g_2021-01-18 001.axgd" and "Animal-10_35g_2021-01-18 002.axgd" are existing twice on your screenshot: download/file.php?id=1908 Zenju, 10 May 2021, 14:10
Yes, you are correct. My situation is not as well controlled as t0ma5's: I am not the only person with access to this Shared Drive, and others mistakenly put duplicates of those files there. However, I obsessively micromanage this Shared Drive, and on the rare occasions when others make changes to it (always via their web browsers, and never using FFS, I'm pretty sure) they usually think to notify me. I regularly use FFS with WinMerge to help me monitor and track unannounced changes (though in this case FFS has blind spots for duplicated files).
It's possible I may not have the whole story on everything that has been done in this drive. For example, someone else's activity might be tied to the suspicious timestamps (and I don't expect any of them to have recollections that I could query now; perhaps the API would know who the actor was?). Regardless, I think we are in agreement that it seems FFS should know that these files already exist on the Shared Drive, since they appeared in the changes list. Would you agree?
Zenju, 10 May 2021, 15:31
I agree, a delay in notifications could have been responsible for that particular issue back in December, where deletions performed manually in Google Drive were not immediately reflected in FFS. Perhaps if I had waited longer, the comparison would have updated properly.
It seems to me that this scenario would require an access restoration notification to be "delayed" indefinitely (never notified). If the delay was only a few minutes, I think the FFS comparison would need to run during that narrow window of time for FFS to strike the files from its database, which seems unlikely in my case; or have I misunderstood?
Still, suppose FFS has struck files from its database. Why then does FFS seem to ignore the recent entries with the suspicious timestamps, which imply the files exist but don't indicate they were trashed?
Perhaps it's not important, but I'm curious: Where is this "GoogleDrive" subfolder, containing the Google Drive database (.db)? I use Windows, so I looked in %APPDATA%\FreeFileSync but didn't find it there. Would there be any use to inspecting it more closely?
jpgill86
Perhaps it's not important, but I'm curious: Where is this "GoogleDrive" subfolder, containing the Google Drive database (.db)? I use Windows, so I looked in %APPDATA%\FreeFileSync but didn't find it there. Would there be any use to inspecting it more closely? jpgill86, 11 May 2021, 02:19
Oops, I'm a dummy and checked %APPDATA% on the wrong computer... I found the database file when I looked on the computer that actually does the syncing. 🤦‍♂️
A fair point! I was lazy and cropped out the private information, rather than blurring it. Here is another version showing that the local and remote sources were on the left and right, respectively, and that the comparison mode was two-way. jpgill86, 11 May 2021, 02:19
Thanks for clarifying! The fact that you're using "two-way" which creates a different DB file (sync.ffs_db) doesn't matter here, because this DB is only relevant for determining the sync directions, *not* current existence of files/folders.
Note that there is one fewer file here compared to the previous screenshot. This is because I intentionally caused the animal 13 file to drop out of the list by opening it on Google Drive in my browser. jpgill86, 11 May 2021, 02:19
Alright. It's good you're keeping the test case unchanged as much as possible.
An excellent experiment. Here is the entirety of what I got after double-clicking on the animal 15 file: jpgill86, 11 May 2021, 02:19
I'm wondering if FFS is also at "newStartPageToken": "13230". I believe it is, but I'll have to see the contents of the Google Drive .db file just to make sure.
So question is why then did the changes list you provided in viewtopic.php?t=7827&start=30#p29606 not lead FFS to conclude existence?
I just noted a peculiarity: The order of change notifications for the first example (it was a great idea you included changes(time)!) and the large time gap between them which implies they were caused by separate actions:
2021-05-06T16:15:11.188Z <shared drive>/Data/Animal-10_35g_2021-01-18/Animal-10_35g_2021-01-18 001 EPOCH-ENCODER.csv
2021-05-06T19:59:07.974Z <shared drive>/Data/Animal-10_35g_2021-01-18
2021-05-06T23:48:25.655Z <shared drive>/Data
There's no way that FFS would conclude "Animal-10_35g_2021-01-18 001 EPOCH-ENCODER.csv" missing at 2021-05-06T16:15:11.188Z.
But what if the real list of changes looked like:
2021-05-06T19:59:07.000Z REMOVED <shared drive>/Data/Animal-10_35g_2021-01-18
...where REMOVED could also be some temporary loss of access!? You're on a Shared Drive after all.
In this case Google would automatically condense the two change notifications
into a single one representing the latest state
How would FFS react to this if a comparison is run right after "2021-05-06T19:59:07.000Z REMOVED"? It would remove the item "<shared drive>/Data/Animal-10_35g_2021-01-18".
But also do one more thing: it would remove the parent folder association for the "<shared drive>/Data/Animal-10_35g_2021-01-18/Animal-10_35g_2021-01-18 001 EPOCH-ENCODER.csv" item, not waiting for the expected change notifications of "Animal-10_35g_2021-01-18 001 EPOCH-ENCODER.csv" that would report a removed parent folder. This second and usually expected change notification does not occur in this example, because the folder is not permanently deleted. Therefore FFS's reaction would be a bug.
If this is what has happened, it would explain all the symptoms! I find it plausible that Google Drive could have temporarily reported a folder deletion/access loss just to have it restored shortly after *without* also sending a change notification for each of its this folder's child elements that the parent folder was removed. I've seen similar behavior with Google Drive's change notifications before. This could be considered a logic bug on Google's side. But anyway, FFS should be robust enough to handle this kind of inconsistency.
To verify this theory, I'll have to have a look at the content of your Google Drive .db file. I hope you haven't done any changes to your Google Drive, so that it is in a state that matches your screenshot download/file.php?id=1911&sid=747fdbe97e53646a93e785f2da98d13f
I guess the change list entry copied above refers to an update to the Last Opened timestamp. However, this JSON output doesn't make that clear. Are there perhaps other fields I can query to show that this change list entry is describing an update to the Last Opened time? And if I query the same fields for the older suspicious entries, might we find out what caused them? jpgill86, 11 May 2021, 02:19
The metadatum that triggered the change notification is probably "viewedByMeTime" https://developers.google.com/drive/api/v3/reference/files
And if I query the same fields for the older suspicious entries, might we find out what caused them?[/b] jpgill86, 11 May 2021, 02:19
Possible. Instead of explicitly specifying the fields you want, I believe you can also set "*" to get all the data available in the change notifications. But more interesting than changes for the files themselves is what happened after that to their parent folders, e.g.:
<shared drive>/Data/Animal-10_35g_2021-01-18  ID: 1eIGNDUMJCr-E0AneocuL-8G8ivUojddD
<shared drive>/Data                           ID: 1RpF7RgJmgYUQ-6r5R3IxoMRnzM5YMeK
<shared drive>                                ID: 0AFnJZoCV2a6RUk9PVA
I regularly use FFS with WinMerge to help me monitor and track unannounced changes (though in this case FFS has blind spots for duplicated files). jpgill86, 11 May 2021, 02:19
The internal model of FFS closely follows that of Google Drive, so these duplicate file names are accounted for. But this concept obviously doesn't fit with normal file system rules that FFS represents on its GUI, so it shows only a single line item. But were you to interact with such a line item in any way, FFS would issue errors about the underlying ambiguity of the file path.
I agree, a delay in notifications could have been responsible for that particular issue back in December, where deletions performed manually in Google Drive were not immediately reflected in FFS. Perhaps if I had waited longer, the comparison would have updated properly. jpgill86, 11 May 2021, 02:19
The delay I've seen is minutes at most, so this theory can probably be dismissed. Still it's really unfortunate that Google Drive can delay change notifications for such a long time, while their web interface on the other hand already shows the more recent state.
Still, suppose FFS has struck files from its database. Why then does FFS seem to ignore the recent entries with the suspicious timestamps, which imply the files exist but don't indicate they were trashed? jpgill86, 11 May 2021, 02:19
I believe the items are still existing in FFS's Google Drive .db files, just the association with their parent folder is severed, thous they're shown as not existing "at this path", but orphaned items (in FFS's view).
If this is what has happened, it would explain all the symptoms! I find it plausible that Google Drive could have temporarily reported a folder deletion/access loss just to have it restored shortly after *without* also sending a change notification for each of its this folder's child elements that the parent folder was removed. I've seen similar behavior with Google Drive's change notifications before. This could be considered a logic bug on Google's side. Zenju, 11 May 2021, 12:35
I might be wrong here. Losing access to a folder but NOT to its contained files actually may be something that the Google Drive model simply allows (unlike normal file systems). Sure, the child items will be orphaned, but they should not be considered deleted.
Technically, FFS correctly considers them orphaned, too, it's just that Google won't send any change notifications for the child items again when parent folder access is restored. Additionally, orphaned items aren't persisted in the .db file by FFS.
jpgill86
I think I've found a way to reliably reproduce the problem (or perhaps just part of the problem, or a related problem)!
1. Give yourself access to a Shared Drive through two accounts with different email addresses, which I'll call email addresses A and B.
2. In FFS, connect to the Shared Drive using email address A and perform an initial sync.
3. Upload any new file to the Shared Drive through a web browser using email address B.
4. Repeat the sync in FFS (still connected with email address A). The uploaded file will fail to appear indefinitely.
After doing this and waiting more than 2 hours, my test file still had not appeared, despite the fact that it appeared in the changes list immediately. Double clicking on the file in Google Drive in a web browser while logged in with email address B (the one that uploaded the file) made no difference, but doing that while logged in with email address A (the one connected to FFS) resolved the problem, causing the file to finally appear in a comparison. If the file is uploaded through a web browser by email address A instead, it will immediately appear in FFS.
My interpretation is that until email address A has touched the new file in some way, it is not seen by FFS. Perhaps FFS is querying the changes list and filtering out changes made by others?
I don't think this can fully explain my situation:
My files that are currently not recognized as existing on the Shared Drive were previously acknowledged by FFS, weeks ago. In fact, they were likely originally put there by me using FFS. Now suppose that one of the other individuals with access to the Shared Drive replaced the original version of the file with an updated version through their web browser. How this is done may result in the file ID changing: uploading via drag-and-drop in the browser should preserve the file ID since it is stored as a new version, whereas deleting the original before uploading will generate a new file ID.
In all my testing, if the contents of a file previously recognized by FFS are changed (new version uploaded) by a different user account (different from the one that FFS is connected to), FFS will have no trouble seeing the change. In contrast, if the file is deleted and then replaced by the different user, FFS will think the file was deleted entirely and never acknowledging the replacement. Indeed, the original file ID was deleted, and FFS apparently cannot see the new file created by the other user with the new file ID.
The reason I think this doesn't fully explain my situation is because my files were not declared as deleted at any point that I can remember; instead FFS simply thinks it needs to copy them to the Shared Drive, as if it forgot that it had previously done so. Perhaps there is another wrinkle to my situation that caused this pecularity.
t0ma5, you said you are the only one with access to your Shared Drives, but that they are managed by different organizations. Do you sometimes access them using email addresses that differ from whatever email you've connected FFS to? You also said you only use FFS to interact with them, so perhaps none of this applies to you...
Thanks for clarifying! The fact that you're using "two-way" which creates a different DB file (sync.ffs_db) doesn't matter here, because this DB is only relevant for determining the sync directions, *not* current existence of files/folders. Zenju, 11 May 2021, 12:35
I very frequently toggle the comparison mode back and force between "Update" (my default, so that I don't lose data when backing up local files to Google Drive) and "Two-way" (so that I can update local files after a collaborator has put a new version on the Shared Drive). Would this create different database files? Could a situation arise where one database knows about a file on Google Drive, but the other doesn't, leading to different behavior?
I'm wondering if FFS is also at "newStartPageToken": "13230". I believe it is, but I'll have to see the contents of the Google Drive .db file just to make sure. Zenju, 11 May 2021, 12:35
I am willing to share my .db file if that will help, though I'd prefer a less public channel since I'm not sure what can be extracted from it (e.g., login tokens).
...where REMOVED could also be some temporary loss of access!? You're on a Shared Drive after all. Zenju, 11 May 2021, 12:35
Firstly, as manager of the Shared Drive, I have greater privileges than my colleagues who are occasionally changing these files. I don't think they can remove my access temporarily to any part of the drive, but I suppose all sorts of transient server shenanigans are possible.
Secondly, for this particular sequence of timestamps, I think something like that is unlikely. The suspicious timestamp, 2021-05-06T16:15:11.188Z, occurred before I embarked on this forum adventure last Thursday, but the later timestamps that same day probably correspond to tests I was doing for this conversation. At no point did I delete those folders. I have noticed that simply navigating to any folder, or to the root of the Shared Drive, will create a change list entry for that node. I think the folder "changes" you have quoted above are just me visiting the folders in my web browser.
Are you saying that Google sometimes rewrites the change list history? My naive assumption was that the page token is a reliable index into an unchanging change list. Then again... I'm seeing now that for the two files I've intentionally "fixed" by double-clicking on them (animals 13 and 15), their change list entries with the suspicious timestamp are gone when I re-query with the old page token, and different entries exist with more recent timestamps. The other entires with the suspicious timestamp remain.
If this is what has happened, it would explain all the symptoms! I find it plausible that Google Drive could have temporarily reported a folder deletion/access loss just to have it restored shortly after *without* also sending a change notification for each of its this folder's child elements that the parent folder was removed. I've seen similar behavior with Google Drive's change notifications before. This could be considered a logic bug on Google's side. But anyway, FFS should be robust enough to handle this kind of inconsistency. Zenju, 11 May 2021, 12:35
Do "run right after" and "restored shortly after" imply that the comparison would need to be run within a narrow window of time, after the access-lost notification is issued but before it is removed again via condensation with another notification? This seems unlikely to happen by chance, especially when I normally run this sync at most a few times per week, and not hundreds of times per day.
To verify this theory, I'll have to have a look at the content of your Google Drive .db file. I hope you haven't done any changes to your Google Drive, so that it is in a state that matches your screenshot download/file.php?id=1911&sid=747fdbe97e53646a93e785f2da98d13f Zenju, 11 May 2021, 12:35
A few things have changed due to the tests I've been running (e.g., animal 15 dropped off the list) and because new data files have been added for a new animal by a collaborator which I have avoided syncing yet, but it's mostly the same. When I share my .db file, I'll make sure you have a concurrent snapshot. Just let me know how I can share it privately.
Instead of explicitly specifying the fields you want, I believe you can also set "*" to get all the data available in the change notifications. Zenju, 11 May 2021, 12:35
Yes, using "*" did expose a lot more data, including "viewedByMeTime" and "lastModifyingUser", but I'm not sure that I've learned anything from it. I'm frustrated that there isn't a field that clearly indicates what triggered the entry! Since lastModifyingUser includes the names and email addresses of some of my collaborators, I'm hesitant to publish the full version here, but would be willing to share it privately along with the .db file.
The internal model of FFS closely follows that of Google Drive, so these duplicate file names are accounted for. But this concept obviously doesn't fit with normal file system rules that FFS represents on its GUI, so it shows only a single line item. But were you to interact with such a line item in any way, FFS would issue errors about the underlying ambiguity of the file path. Zenju, 11 May 2021, 12:35
Ah, yes, I have seen that before. Thanks for the clarification.
I believe the items are still existing in FFS's Google Drive .db files, just the association with their parent folder is severed, thous they're shown as not existing "at this path", but orphaned items (in FFS's view). Zenju, 11 May 2021, 12:35
OK, I hope that inspection of my .db file might be able to determine if you are right!
Technically, FFS correctly considers them orphaned, too, it's just that Google won't send any change notifications for the child items again when parent folder access is restored. Additionally, orphaned items aren't persisted in the .db file by FFS. Zenju, 11 May 2021, 12:43
Haha, OK, so maybe inspection of the .db file will not be so helpful? Still happy to share.
Boy, these posts are long, haha.
jpgill86
I just noticed that my Shared Drive's "Data" folder (the root for the sync) contains two sync.ffs_db files. o_O One was last modified a few minutes ago, and the other was last modified April 26.
4. Repeat the sync in FFS (still connected with email address A). The uploaded file will fail to appear indefinitely. jpgill86, 12 May 2021, 01:54
Wow, I can reproduce this!
It's the standard Shared Drive scenario not working!
After doing this and waiting more than 2 hours, my test file still had not appeared, despite the fact that it appeared in the changes list immediately. Double clicking on the file in Google Drive in a web browser while logged in with email address B (the one that uploaded the file) made no difference, but doing that while logged in with email address A (the one connected to FFS) resolved the problem, causing the file to finally appear in a comparison. If the file is uploaded through a web browser by email address A instead, it will immediately appear in FFS. jpgill86, 12 May 2021, 01:54
Problem is, FFS isn't receiving any change notifications from Google. Only after you access an item as you described, change notifications are received by FFS.
How can this be when FFS sets includeItemsFromAllDrives?
I've read Google was planning to deprecate this parameter middle of last year, but then didn't. In any case, the behavior is not what one would think it is. "includeItemsFromAllDrives" definitively does NOT include items from all drives. Unfortunately this is what FFS was expecting.
https://developers.google.com/drive/api/v3/enable-shareddrives
includeItemsFromAllDrives     driveId     Query Description
true     No     Changes are reflective of changes to files inside or outside of shared drives that the user has accessed, as well as changes to shared drives in which the user is a member.
true     Yes     Changes are reflective of changes to the particular shared drive that was specified and items inside that shared drive.
FFS doesn't set the drive id, so we have
Playing language lawyer, this is exactly the behavior we've seen. One would assume that "changes to shared drives" would include also changes to files in shared drives, but this is not what is happening in practice, and if it were, the first part of the sentence would be redundant.
So... everything works as described by Google. Except, the variable name "includeItemsFromAllDrives" is a blatant lie (but surely was not when I implemented Shared Drives in FFS more than a year ago).
I don't think this can fully explain my situation: jpgill86, 12 May 2021, 01:54
I agree, for the files to be seen as deleted, there must have been a corresponding change notification at some time. An update doesn't generate such a notification, only a proper delete + a new upload, assuming the notification for the upload is somehow not received by FFS.
I very frequently toggle the comparison mode back and force between "Update" (my default, so that I don't lose data when backing up local files to Google Drive) and "Two-way" (so that I can update local files after a collaborator has put a new version on the Shared Drive). Would this create different database files? Could a situation arise where one database knows about a file on Google Drive, but the other doesn't, leading to different behavior? jpgill86, 12 May 2021, 01:54
Doesn't matter. Sync.ffs_db file have no say on whether a file exists on Google Drive or not.
Are you saying that Google sometimes rewrites the change list history? My naive assumption was that the page token is a reliable index into an unchanging change list. jpgill86, 12 May 2021, 01:54
Google condenses change notifications. You won't find more than one change notification per item.
After more thinking: Theory is moot. Even if Google Drive would emit a change notification for a deleted folder, without notifying child items, FFS will behave correctly, because FolderContent::isKnownFolder will be false. So the next access, should this folder reappear, will trigger a rescan. The FFS implementation in this regard is actually pretty much ideal, because it also covers the case of the folder *not* reappering without accumulating orphaned file items needlessly.
So all in all, there is one big TODO for FFS: Fix receiving change notifications for Shared Drives.
jpgill86
Wow, I can reproduce this! Zenju, 13 May 2021, 16:42
Progress!
FFS doesn't set the drive id Zenju, 13 May 2021, 16:42
In all my testing, I always set driveId, thinking it was necessary. However, I see in FFS's getChangesDelta that driveId is not included among the query parameters. Looks like this parameter makes all the difference. If it's not included, the file uploaded by a different email account will not appear in the changes list; if it is included, it will be. Could FFS start using driveId in getChangesDelta? Note that getStartPageToken returns a very different token depending on whether or not driveId is provided.
I've read Google was planning to deprecate this parameter middle of last year, but then didn't. Zenju, 13 May 2021, 16:42
I see that there is a deprecated alias, includeTeamDriveItems. Are you perhaps thinking of that?
So... everything works as described by Google. Except, the variable name "includeItemsFromAllDrives" is a blatant lie Zenju, 13 May 2021, 16:42
I completely agree with your assessment, haha!
