Been using Beyond Compare; just discovered FFS, and loving the moved file detection.
But BC has a feature called "alignment override" ... which allows me to specify a regex rule for matching items with different names. Folders on the destination have prefixes which I want to ignore.
For example, I can specify that a source folder called `202010_FooBar1` should be synced to destination folder `FooBar1` by specifying that `\d\d\d\d\d\d_(.*)` aligns with `$1`
Does FFS have anything like this?
Thanks!
Regex matching rules?
It does not, you would have to set up a folder pair for each of the instances that occurs
